USRP Software Radio
USRP2920 50Msample/s
Hi
it's possible to set the sample rate of the USRP 2920 NI at 50 Msample/s or only at 25Msample/s
I need more sample rate..
by
Francesco
Message 1 of 8
(7,682 Views)
Hi Francesco,
To set the sampling rate above 25MS/s, you will only be able to acquire 8 bit data instead of 16 bit data.  You can do this using a property node and changing the Sample Width, Expected Peak, and Host Data Type properties.  There is an example that ships with the driver that shows this call niUSRP EX Rx Customize Fetch Type and Sample Width.vi.
Whether or not you will be able to maintain a higher sampling rate will be dependent on your host machine.  The Ethernet port on your computer will effect this as well as things like the write speed of your hard drive.  Writing 50 MS/s of data to your hard drive may not be possible.  I used a RAID array for previous application where I was collecting data at 50 MS/s to prevent disk read/write speed from becoming an issue.  Maintaining this high throughput level over Ethernet can be difficult.  If you have issues, look at this post for some suggestions.
Sarah Yost
Senior Product Marketing Manager
Message 2 of 8
(7,681 Views)
I don't see the voice sample width in the property node ...  and also the example
please help me
Message 3 of 8
(7,675 Views)
Hello jtudor,
Please ensure that you have NI-USRP driver version 1.1
From the property node select Configuration » Advanced » Sample Width
Anthony F.
Staff Software Engineer
Message 4 of 8
(7,673 Views)
yes I have 1.0 driver version
I need to update the driver
thanks
Message 5 of 8
(7,667 Views)
Hi JTudor,
If You got Your answer, please set Anthony_F's as the correct one.
Thanks in advance.
Mattia.
Message 6 of 8
(7,643 Views)
Hi Anthony
I just installed the Driver 1.1 but Labview return me an error related to the FPGA
not update
where  can I find the correct firmware ?
thank you
Message 7 of 8
(7,630 Views)
Hi jtudor,
You can find a tutorial of how to change the FPGA image and the firmware in this knowledge base article:
http://digital.ni.com/public.nsf/allkb/F622E3B3B9CC34B6862579D500705272
Sarah Yost
Message 8 of 8
(7,628 Views)
