USRP Software Radio
USRP2940r customize FPGA run with Ethernet
I am using NI USRP 2940R as FPGA target. I have written the code and it is working fine when it runs with PCI Express Connection.
Now i want to run my USRP (with the customize FPGA) through ethernet connection but i don't think my code (written on FPGA, Streaming Xcvr) works . . . Is there some thing i am missing . . .
In Addition,
Examples via the Windows start menu: All Programs --> National Instruments --> NI-USRP --> Examples are working normally . . .
(3,096 Views)
Hello!
When using the NI USRP RIO, the PCIe interface is required to use LabVIEW FPGA to customize the bitfile.  You can use ethernet when using NI-USRP with one of the default bitfiles only.
Jon F.
Technical Support Engineer
(3,066 Views)
Thanks for your reply Jon F.
Yes i know PCIe interface is required to use LabVIEW FPGA to customize the bitfile but after Customization i want to run this customized bitfile through Ethernet.
Is it Possible . . ?
(3,019 Views)
This will not be possible through the ethernet interface.  The USRP RIO can not run headless, and the bitfile is downloaded to the device every time you run host code which calls a custom bitfile.  This is only supported through the PCIe connection, so using any bitfile outside of the defaults will not work.
Jon F.
(3,012 Views)
