USRP Software Radio
Unable to add USRP 2974 hardware to LabVIEW Comms 3.0
I have a NI-USRP 2974 and is trying to operate the device using a Windows machine with LabVIEW Communication Systems Design Suite 3.0. The NI-USRP 2974 has LabVIEW Communications Real-time 3.0 installed in it. I intend to operate the SDR through a direct ethernet connection and will also be using LTE Application Framework 3.0. The version of my NI-USRP instrument driver is 21.0.
However, if I try to add the USRP 2974 hardware to my project using the System Designer. I encounter the error 'NI System Management Server is not installed or running on this machine'. I have attached the screenshot for further reference.
I hope someone could help me how to resolve this issue. Thanks!
Message 1 of 1
(1,176 Views)
