USRP Software Radio
Use of NI USRP-2945 configuration blocks in a loop.
Hello everyone,
I am implementing block configuration for the use of NI USRP-2945 with the objective of sweeping frequencies to enter as Carrier Frequency. Said sweep is done with a loop, and I would like to know what blocks and / or properties the NI USRP-2945 allows to be reconfigured every time the Carrier Frequency changes, since it seems that the device does not tolerate the reconfiguration of some of them . The blocks and / or properties I use are shown in the attached screenshots, however I would like to know which of them can be used more than once.
Thank you for your attention.
Message 1 of 1
(2,007 Views)
