USRP Software Radio
What FPGA-Image to use for the X300 with LabVIEW and NI-USRP 15.0?
Labview refuses to communicate with my X300:
niUSRP Open Rx Session.vi<ERR>A runtime or configuration error occurred.
Code: 1440
Details: RuntimeError: Expected FPGA compatibility number 13, but got 15:
The FPGA image on your device is not compatible with this host code build.
Download the appropriate FPGA images for this version of UHD. ...
Which image is the right one to load into the X300?
Message 1 of 14
(7,492 Views)
Hey Standardnutzer,
"Details: RuntimeError: Expected FPGA compatibility number 13, but got 15:"
Which Version of LabVIEW do you have installed on your PC?
Please also look at this link:
USRP Hardware Driver and USRP Manual: USRP X3x0 Series
http://files.ettus.com/manual/page_usrp_x3x0.html
Greetings,
Brandizzl
Message 2 of 14
(7,476 Views)
Hi Brandizzl,
I am using LabVIEW2015 (64Bit).
The FPGA-Version the LabVIEW driver is referring to (version 13 or 15) does not match in any way the nomenclature at the ettus website (008.003.001).
Message 3 of 14
(7,472 Views)
Wouldn't it be better to ask Ettus for this question: support@ettus.com
Greetings
Brandizzl
Message 4 of 14
(7,469 Views)
The NI-USRP driver installers include compatable FPGA images which are by default installed at: C:\Program Files (x86)\National Instruments\NI-USRP\images.  There is a utility to check image versions and update images located at: Start » All Programs » National Instruments » NI-USRP » NI-USRP Configuration Utility, which should direct you to the correct image file for your device.
Message 5 of 14
(7,457 Views)
Here's a link to the NI USRP Getting Started guide: http://www.ni.com/pdf/manuals/375717e.pdf
The Updating Device Firmware and FPGA Images section goes over the information alynch outlined.
Message 6 of 14
(7,449 Views)
This won't work for the Ettus X300.
Message 7 of 14
(7,444 Views)
Follow alynches advice. Thats what I did with the x310 & it worked. I'd be interested in knowing what throughput you get with the x300. I couldnt get past 8 Msps using the 1gbit ethernet interface using labview (which was still 8 times faster than what I got from matlab.)
Message 8 of 14
(7,427 Views)
Dear all,
Yes,I met the same question.The NI-USRP Configuration Utility path only find X310_fpga.But coucld't find usrp_x300_fpga_HGS.bit.
I have read the document of NI-USRP15.0,From the document,and the X300 was supported.
How coucld  i solve the problem.
Thank you.
best regards
John
Message 9 of 14
(6,687 Views)
Dear all,
Thank you.
best regards
John
Message 10 of 14
(6,685 Views)
