USRP Software Radio
What is the difference between the REFin and PPSin? May I use the PXI 5652 to synchronize USRPs?
Hi, everyone!
I am working on a project which I need to synchronize 8 USRPs(USRP 2920) as receivers. And it seems that PXI 5652 has a REF out connector, so I decide to use it as the reference clock of the 8 USRPs. But I do not know how to connect the PPSin, and in fact I am confused of the difference between the REFin and PPSin.
thanks!
(6,178 Views)
Accepted by topic author Jay_c
Hi Jay_c,
In brief,
Ref In is the terminal for the USRP device to accept a external reference frequency signal (10Mhz).
PPS In is the terminal for the USRP device to accept a external time base clock source signal (1 pulse per second )
You can refer to this white paper for a detailed description about 8*8 MIMO system.
Please refer to the "Timing and Frequency"  section for information specific to your question.
http://www.ni.com/white-paper/14311/en/
I am not sure whether you can use the 5652 signal generator specifically for your application.
(5,865 Views)
