USRP Software Radio
Where are is the "QAM Modulation of an ASCII String" Example?
The text message is converted into a bit stream using USRP and the communication experiment using the QAM modulation method is proceeded.
I try to refer to the "QAM Modulation of an ASCII String" example in the past bulletin board, but I can not search it.
If you have the example or have any related matters, I would appreciate it if you advise me.
(1,464 Views)
want to conduct research to transmit and receive text messages using
QAM modulation and demodulation.
If you have any related data or examples, I would appreciate it if you let me know.
(1,451 Views)
