USRP Software Radio
Whether should i set the modulation index in the amplitude demodulation module?
When i designed the receiver-side  of amplitude demodulation,i found the receiver signal isn't stable .So i search the problem and found when I don't set the modulation index in the amplitude demodulation module, the receiver signal become stable.If i set it, it become unstable.Who can tell me whether i should  set the modulation index in the amplitude demodulation module? and how should i modify it? Thank you!
Message 1 of 1
(4,492 Views)
