USRP Software Radio
audio transmission example using USRP
I am looking for an example vi for transmittng and receiving audio signal using usrps.
JK
(7,372 Views)
Hi josephkirmani,
Here are a couple examples of Tx and Rx using FM on a USRP. Is this what you are looking for?
https://decibel.ni.com/content/docs/DOC-39321
https://decibel.ni.com/content/docs/DOC-24206
https://decibel.ni.com/content/docs/DOC-25893
Justin M.
Applications Engineering
(7,355 Views)
Is not there any example which uses any other modulation rather than FM. Such as QPSK, BPSK etc.
(7,329 Views)
Hi josephkirmani,
You can see more examples if you have NI USRP installed and go to:
C:\Program Files (x86)\National Instruments\LabVIEW 2014\examples\instr\niUSRP\ModulationToolkitExamples
Justin M.
(7,320 Views)
Disculpa actualmente quiero realizar esta practica pero no encuentro mucha información, quisiera saber si pudiste realizar la practica ? o tienes algún link que me ayude
 De antemano
muchas gracias.
JK
(4,715 Views)
If you are looking for examples, you can navigate to
If you cannot find this directory, it is possible that you do not have Modulation Toolkit installed. It is included with NI-USRP, but you can also install it from our website.
We also have a Spanish forum you might be interested in.
Stephen Chan
(4,705 Views)
