USRP Software Radio
cannot ping X310 at first start up
I purchased the USRP X310 with a Basic TX daughterboard installed. My plan is to use it via 10GbE together with LabView with a Win10 host machine. I have connected the SDR with an Ethernet cable using Port 0 and the included SFP+ adapter to my host PC's (1GbE) ethernet interface for network testing purposes. The ethernet adapter is configured to use the static IP 192.168.10.1. Furthermore I have installed the UHD (uhd_3.15.0.0-release_Winx64_VS2017.exe). However when the device is connected and powered on, I can neither ping 198.168.10.2 (Request timed out.) nor detect it running the uhd_find_devices.exe. I have also started the NI-USRP Configuration Utility which I recently updated but it was not able to detect the SDR either. I do observe that none of the LEDs on the back is illuminated (especially not the Port 0 ethernet). How can I get it working?
(3,249 Views)
Please follow the steps described in this link
https://files.ettus.com/manual/page_identification.html
bhovhann
(2,962 Views)
