USRP Software Radio
choosing usrp antennas
Currently i'm working with USRP 2920 and with one antenna (VERT 400) to transmitting a signal. I'm kind of new on this. I want to use USRP transmitter with a different antenna (one with more Gain). I would like to know if there's something that i should be care about connecting a different antenna that the one that's recommended in the USRP manual. I know that i have to be aware of the input impedance and the frequency range if the antenna. Is there another caution that i should take?..
(3,951 Views)
Hello morenod.
Thanks for posting, you are ok, those are the only two considerations you need to take into account when you want to use a different antena besides the recommended one.
(3,900 Views)
