USRP Software Radio
converting X310 to NI USRP RIO
Thank you for this information. This really helps.
Message 11 of 13
(1,009 Views)
Hello Dylan, I want to use NI USRP RIO as X310 with UHD for a small application and then convert it back to NI USRP RIO. I checked this https://kb.ettus.com/Converting_an_X310_into_an_NI-USRP_Rio and noted that "Note there is no method at this time to load DC offset corrections without sending the unit back to the factory."
Is there any update on this? Do I loose DC offset values when converting back to NI USRP RIO?
Message 12 of 13
(802 Views)
Hi Avinaash,
There still isn't a method to load DC offset corrections without sending the unit back to the factory.  You will lose the DC offset values when converting back to NI USRP-RIO.
Message 13 of 13
(789 Views)
