USRP Software Radio
converting x310 to NI-USRP RIO
Hi I am new to USRP ettus X310, I have connected it with both Ethernet cable and PCIe x4, going through the instructions in the manual of the USRP and how to set it up,  I found the my USRP x310 with UBX daughterboards is similar to NI-USRP 2944R, and I tried to run the simple streaming sample project "TX and Rx streaming host.vi" on LabView.
Before this I tried to convert it from from x310 to NI-USRP Rio following the steps in the link:
https://kb.ettus.com/Converting_an_X310_into_an_NI-USRP_Rio
the first step "The daughterboard IDs need to be burned into the EEPROM" has gone correctly without any errors while the second step "IQ imbalance corrections need to be loaded into the EEPROM" gives an error and I attached a screenshot of the error.
I don't know what is the problem exactly and I spent a very long time trying to solve this, so I would appreciate if anyone could help in solving this.
Best Regards,
Ahmed
(3,035 Views)
Hi Ahemd,
I would post that to the Ettus Team:
https://www.ettus.com/support/
Best,
Chase
Chase
NI Technical Support Engineer
(2,968 Views)
