USRP Software Radio
demodulation of GMSK using usrp and labview
hello everyone,
I want to demodulate GMSK data using LabVIEW and usrp.for this I use MSK example from modulation toolkit and choose filter type:  Gaussian filter but  unable to demodulate the data.
kindly help me in this issue.
(3,130 Views)
You need to look at the signal closely.
1. Where is the signal coming from ?
2. What is the symbol rate ?
3. What are trying to measure? EVM ? MER? BER? Raw Bits etc.
4. If you know of a known sequence in the message, you can try that sequence for synchronization
Hope the above helps. Let me know if you still face issues.
Regards
Sastry
Sastry Vadlamani
RF Principal Software Engineer
Aerospace and Defence BU
Certified LabVIEW Architect
(3,081 Views)
hi Sastry,
thanks for your reply
1-The signal is coming from digital radio.and received using usrp 2944.
2-the symbol rate is approx 3-4k.which is not known exactly.
3-i want to demodulate the signal and listen audio.
->I don't know how many samples per symbol is used.?
->How to demodulate the gmsk signal without knowing its modulation parameters?
(3,070 Views)
