USRP Software Radio
designing a text file transceiver using 2 usrp 2900 blocks.
Hi all,
I am trying to send and receive a text file using 2 usrp 2900 blocks. when I use only one usrp block, the system works fine. maybe it is because the transmitting and receiving antenna are close and located on the same block. However, when i try to do it using 2 blocks, it can send but cannot receive.
I am really stuck now and would welcome any help.
Thanks.
Niall
(2,551 Views)
Few suggestions:
  1. Try setting the LO frequency away from the carrier frequency. Refer this KB http://digital.ni.com/public.nsf/allkb/DE8F06E9223230C286257E6F006FF7A5
  2. You can try to up the Tx and/or Rx Gain.
  3. Make sure that you are using the right antenna for your frequency of operation, if an inappropriate antenna is used it may cause unexpected attenuation as per it's frequency characteristics.
(2,534 Views)
