USRP Software Radio
frequency hopping time of NI-USRP 2922 ??
I want to make  frequency hopping with NI-USRP 2922 but I want to know the time of  frequency hopping...
Thanks..
(4,956 Views)
Do you mean that you need to know how much time it takes to switch frequencies with frequency hopping?  From other posts on here, it appears that this time can vary depending on the strategy you use to do this.  If you change the frequency using a property node, it looks like people have been getting somewhere between 10-50ms.  Here are a few other forum threads you may or may not have seen which talk about using frequency hopping with USRP:
http://forums.ni.com/t5/USRP-Software-Radio/How-to-switch-central-frequency-fastly-with-labview-and-...
http://forums.ni.com/t5/USRP-Software-Radio/Synchronizing-carrier-frequency-of-two-USRPs/td-p/199030...
Jon F.
Technical Support Engineer
(4,928 Views)
Thanks for your help Jon F.
I'll look the links you sent..
(4,918 Views)
