USRP Software Radio
generating 100Mhz signal in Labview
How can we generate 100Mhz signal in labview using NI USRP-2943R
(2,210 Views)
here is the block diagram for 120MHz.
Also check the getting started guide for usrp.
Regards.
(2,161 Views)
Thank you sir. sir can you please send me the block diagram or module in the labview , how can i generate the signal of 100 Mhz in labview.
my email id : prashant.dhungana1999@gmail.com
(2,156 Views)
Here is the link, You can generate Your code using this examples, If not follow this steps for finding an example in LabVIEW.
Regards.
(2,145 Views)
