USRP Software Radio
how exact is the time resolution by using GPS time from the USRP?
Hello
I´m using a USRP 2932.
I need the time from the GPS signal. I need the Time exactly as possible.
How exact is the time that i can get from GPS with the USRP? 10e-8 s, 10e-9 s, ... or better
When I use the function "niUSRP timestamp to LV timestamp",  i see the actual time and date.
The resolution is 1x10e-8s. GPS Time accuracy should be at 1x10e-10s.
Best,
Mathias
(4,135 Views)
Hey,
check out this topic:
Time accuracy of GPS timestamp - NI Discussion Forums
https://forums.ni.com/t5/LabVIEW/Time-accuracy-of-GPS-timestamp/td-p/3230022
The difference between GPS and the internal OCXO Clock is going towars 0.01 ppb accoring to the ni Homepage Overview:
NI USRP-2932 - National Instruments
https://www.ni.com/en-us/support/model.usrp-2932.html
Regards
(4,103 Views)
