USRP Software Radio
how to plot 3D spectrogram using usrp2920 spectrum sensing output
hi,
i'm woring on Real-time spectrum sensing using usrp with labview. i would like to know how to plot the usrp baseband spectral info as a 3D spectrogram over the time interval of sensing.
(4,485 Views)
You can use the 3D graph from the 3D graph palette in LabVIEW.
You can use shift registers in a loop to catenate each new spectrum measurement (array) to Z matrix (which is the values matrix). This will create a kind of flow effect.
(4,338 Views)
