USRP Software Radio
labview fpga on usrp x310 with cbx120
Dear all,
From another post,we know:
        1.LabVIEW Host driver " ni-usrp".  This uses UHD under the hood and allows X300/ X310 / USRP 294x to act like an N210 or NI USRP-292x device.  This should work out of the box.  Both ethernet and PCIe connectivity are supported.
       2. LabVIEW FPGA driver "ni-usrp rio". This allows USRP 294x devices to be programmed from LabVIEW FPGA. The entire FPGA firmware is new, and written in LabVIEW, and is therefore completely customizable in LabVIEW. UHD is used on the side as a look-up table for some FPGA settings but is not directly used.  X310 support in this mode is not enabled by default.
but ,I have a question,the driver of  " ni-usrp" and  "ni-usrp rio" is different?That is to say,if we want to develop application on LabVIEW FPGA with x310,we have to install " ni-usrp" and  "ni-usrp rio"?where can we find the driver "ni-usrp rio"?
(4,263 Views)
The NI-USRP installer will provide support for both the niusrp host driver and ni usrp rio driver.
One you install it, a good place to start would be the USRP sample project templates which are available through the create project option in labview.
(4,238 Views)
thank you!
(4,218 Views)
