USRP Software Radio
message timing problems
This should be easy, but it gives us great headackes.
I'm trying to send accuratelly timed messages. The messages should be timed at intervals of 5 sec. or more. I'm using a URSP-2930, so the timing should be <25 ns accurate. When I send a message triggered a timestamp, we see some very weird things.
The USRP says there is a lock. But when we compare the send signal start to a reference 1 pps, the time offset is 2.6 us (too late).
There is a gps lock, but there does not seem to be a way to check if there is a valid time lock. The ni site says that it's possible to read the skpi output of the firefly. This seems to be copied from the ettus site, the LV driver does not seem to have this option. So how can I check if there is a time lock?
When I send the message in 127 parts, 8192 samples (stream several parts, and end the stream the last message), the next message time jumps 10 us, so the total offset is 12.6 us. So this is a huge jump compared to the 25 ns accuracy! The message is correct though... When I send <5 parts, it jumps back to the regular offset of 2.6 us! In this case we don't have long signals, so we can send it as one part. It's still weird.
I checked this on two PC's, with three USRP's and the USRP example and my own code. It's very reproducable.
I'm sending 1-10 MHz IQ rate (configurable), at 400 MHz, with a LO of about 420 MHz, with the NI-USRP 1.3 driver
Does anyone have any ideas about:
1) the offset of 2.6 us
2) how to know if there is a time lock
3) the jump when sending the signal in parts
Any help is greatly appreciated,
Wiebe.
Message 1 of 12
(6,685 Views)
Hello Weibe,
Are you able to attach your code so I can try to reproduce the error and look for potential reasons for the delay on my end?
Brad S. | National Instruments | CLA
Message 2 of 12
(6,655 Views)
Hi Brad,
Thanks for the response.
The attached VI is one of the modified examples. Sorry about the messy wiring, it's copied from the USRP example. It shows the exact problems we're having with the production code. I think it must be a combination of problems:
This could be cable length difference between the GPS antennas? Would expect something like 100 ns...
This is simple because NI did not make a SCPI interface. So if there is a GPS lock, there might not be a frequency lock. So the 1 pps will not be stable, and there is no way to tell.
We don't need this now, so we choose to ignore the problem (we've got too many real problems at the moment).
Wiebe.
Message 3 of 12
(6,616 Views)
Wiebe,
To help with number two, you can add GPS Lock Status to you niUSRP property node. This should allow you to know when the GPS is locked. Refer to figure 5 at the following link.
https://www.ni.com/en/shop/wireless-design-test/what-is-a-usrp-software-defined-radio/global-synchro...
Can you give me details on how you are calculating the 2.6 us time delay? Information on what time stamps you aer using and how you are comparing the data to get 2.6 us for example. The more information the better.
What is your overall setup? Are you only using one USRP 2930? Where is the PPS signal coming from?
Message 4 of 12
(6,606 Views)
I forgot to mention, try setting up your trigger after your GPS is locked. As of right now your code is triggering while you are trying to establish the the GPS lock.
You can use the GPS Lock Status property to control a gas structure for error handling as well.
Please let me know how that goes.
Message 5 of 12
(6,604 Views)
Brad,
Thank you for the input.
I know how to check for a GPS lock, but does this mean there is a frequency lock? Usually, a GPS lock needs to be present for maybe 10 min. before a stable freuqncy lock is possible. Only when there is a stable frequence lock, the 1 pps is reliable. You can check the reliability of the firefly's 1pps with the SCPI interface (if it was actually there).
We set the time stamp on x.000000 seconds. So the signal should be send exactly at a 1 pps. We don't calculate this, we use a two channelscope, 100 MHz (an NI PXI digitizer card) , and put the signal on one channel, and a 1 pps on the other.
The USRP has the 1 pps internally comiing from the firefly. The other 1 pps comes from either another firefly (from another USRP) or a spetentrio gnss receiver. In the original setup, we capture the USRP's signal and a second 1 PPS signal.
We've looked at the timing difference between the 1 PPS of two USRPs filreflies, it's < 100 ns.
We've looked at the timing difference between the 1 PPS of a USRP firelfy, and the GNSS receiver, it's <250 ns after 10 minutes firefly warmup-time. This will probably get less after more time.
We've looked at the time difference between the 1 PPS of a USRP filefly, and the signal of the USRP's firefly, and it's exactly 2.6 us!
If there is no lock, this is true for the 1st next message. As soon as there is a lock, the next trigger is set up while there is a lock. The problem remains.
But even in the current code, the firefly can have a lock at the moment the USRP code starts running.
I also had the wait for lock in front of the code, and it behaves the same.
I also had a has lock property node in a loop waiting for a lock before all the other code, and it behaves the same.
Not sure what you mean with "gas structure". Anyway, there should always be a lock in our system. Still we need to be able to send messages if a user chooses to ignores the fact that there is no lock. If there is a lock, and we do set up the trigger when there is a lock, the offset of 2.6 us is there.
Wiebe.
Message 6 of 12
(6,593 Views)
Wiebe,
Gas was a typo, it was suppose to be CASE.
I have gotten a hold of a USRP 2930. I am going to try to see if I can replicate the 2.6 us delay.
Message 7 of 12
(6,577 Views)
Brad,
Thanks in advance.
We've found that the 2.6 us is very repeatable. But the bad thing is, when we leave the USRP running overnight, it either jumps or slights to 1.6 us. For a static error we can correct, but if it moves this is impossible...
Wiebe.
Message 8 of 12
(6,565 Views)
It seems that the installed driver version is significant.
1.2 > no problem.
1.3 > not working, 2.6 us delay!
1.4 (or "14") > no problem.
We've done some tests and the 1.3 driver gives bad results. It's still too early to say that this solves all the problems, but it's the first breakthrough we've had in a few weeks.
The FPGA FW 14 version seems compatible (or exactly the same) as the 1.3 version. When we installed the 1.3 driver firmware on the USRP, and run the example VI on a 14 driver PC, we didn't get any complaints about the driver version. The problem is not there though. So this implies that the problem is in the PC part of the 1.3 driver...
What is weird is that 14 does not seem to fix anything related to this topic. Maybe an insider can confirm that something did change?
Wiebe.
Message 9 of 12
(6,528 Views)
Hello -
Can you describe your test setup? It's not clear how you are conducting these tests. We have not observed or been able to replicate the challenges you are seeing.
Message 10 of 12
(6,525 Views)
