USRP Software Radio
ni usrp example are not running on window 7 64 bit
i have installed labview 2012 ,modulation toolkit, mathscript toolkit and usrp device driver 1.2. i am using window 7 64 bit operating system. i am trying to run example of usrp but it was not running it is not able to load NI-MAPro.lvlib files .any other toolkit required to be installed to run examples of ursrp ...please help  i am new to usrp and labview.
(6,266 Views)
I run windows 7 64 bit. However only LabVIEW 32 bit is supported.
(6,260 Views)
I have installed labview 32 bit on my computer but window 7 is 64 bit ,labview is woriking fine...to run usrp example do i have install window 7 32 bit.
(6,253 Views)
My working system is Windows 7 64 bit running the LabVIEW 32 bit. Everything works fine with this combination.  Where do the error messages occur?  Are they for specific examples?
(6,251 Views)
well most example of modulation toolkit and other like  EX FM demod sound card (queue), ex fsk tx,ex pam rx , ex pam tx, psk, QAM  ....allmost all example are creating poblem..whenever i click it start loading file but it is not able load NI_MAPro.lvlib it ask for file path but i donot where these files are located.for example if i click to open FM Demod sound card (queue) example it is not able laod file NI_Mapro.lvlib:fft power spectrum for 1 chan(cdb).vi
(6,240 Views)
