USRP Software Radio
niGPS Toolkit-USRP: Adjust sattelite power, Simulate more than 8 satellites
I'm using a modified vi (attached) from the original one found here to generate a trajectory (also attached), but I can't generate more than 8 satellites (even if I set the "Maximum Number of Optimal Satellites" control to +8). Does anyone know why?
Also, as the "gnss_configure relative power levels and enable satellites.vi" subvi wasn't attached in the "niGPS Direct Streaming Generation - USRP trajectory.vi", I modified it so I could generate my signal, but I'm not able to configure the satellites relative power levels anymore. I would like to create a cluster like the "Satelitte Cluster" to do it, but I'm not sure how do configure it correctly. Can anyone help me?
I'm using an USRP 2932, niGNSS Simulation toolkit 3.0 and the LabView 2014 SP1.
I would really appreciate if someone could answer this questions.
Luisa
Message 1 of 1
(2,458 Views)
