USRP Software Radio
niGPS- change to trajectory mode on the fly?
is it possible to change from a defined receiver location to trajectory mode on the fly with the gnss toolkit?
Thanks in advance
(3,254 Views)
Hi Puschka,
what hardware and software do you use exactly?
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(3,212 Views)
Hello MelanieE,
thanks for your reply!
I'm using the USRP 2932 and GNSS Simulation Toolkit 3.0 with labview 2014.
To be more precise: Is it possible to change to trajectory SCRIPT mode on the fly?
Puschka
(3,209 Views)
Hi Puschka,
thank you for your reply.
The following link should help you with your question:
On the Fly Input Mode - NI GNSS Simulation Toolkit Help - National Instruments
http://zone.ni.com/reference/en-XX/help/372446D-01/nigpshelp/on_the_fly/
Additionally I recommand to update your GNSS Simulation Toolkit since version 3.0 is only supported until LabVIEW 2012.
Melanie Eisfeld
(3,204 Views)
Hallo MelanieE,
So, I could link the converted path of a trajectory.txt file without the "begin" and "end" statements to this property node arg. ?
Or can it process only one command at a time?
You mentioned a newer version of the toolkit. What version is the latest?
Thank you for your help!!!
Best regards
Puschka
(3,201 Views)
