USRP Software Radio
problem with UBX-40
At first I used NI USRP 2920,replace Wbx-40 with Ubx-40,program and working properly。When I run the same program In Ettus N210 add Ubx-40,it report error as:niUSRP Initiate.viA runtime or configuration error occurred. Code: 2410 Details : LookupError:Path not found in tree:/mboards/0/dboards/A/rx_frontends/0/sensors/lo_locked. How can I avoid this error? The software is LabVIEW 2015 and USRP 16.0. Thanks for your advice!
(2,671 Views)
hi, is it possible to confirm that the firmware and FPGA images on the USRP-2921 have been updated to the one for your driver? This can be done by carrying out the steps outlined in the following knowledgebase article:
http://digital.ni.com/public.nsf/allkb/F622E3B3B9CC34B6862579D500705272?OpenDocument
(2,505 Views)
