USRP Software Radio
signal unstable at maxiumum bandwidth
Hello all,
I have a base band signal with a bandwidth of -0.8Fs to 0.8Fs (Fs = sampling rate).  I saw on other forums that we use +-0.8Fs as bandwidth because of the decimation factor.
However, when I go about around a 40MHz sample rate with many signals the signals become very unstable.  They are not always transmitting and keep cutting in and out.
Would this be because the computer I am using can't keep up with this sample rate?
Or is this because I am running into a USRP hardware issue?
I am using a B210 board.
Thanks!
Message 1 of 1
(1,995 Views)
