USRP Software Radio
simultaneous recieving and retransmitting of packets
hi
i am using the packet TX RX vi to make a corporate communication network which involves a source and a transmitter to communicate with each other using a elay. the relay should recieve the packets from the source, amplify them and retransmit them to the destination. for this i need to combine the transmitter and the reciever in such a way that it recieves the data and retransmits it simultaneously. but i am unable to do so because the transmitter and reciever donot work at the same time. how can i join these vis to form one vi that can do my task.
PFA the tranmitter and the reciever vi which was taken from the ni website. the relay vi is the one that i tried to join.
i would be thakful for any help
thanks
(3,327 Views)
Accepted by topic author nauman_malik1112
Here's a forum post which seems to answer your question: https://forums.ni.com/t5/USRP-Software-Radio/Can-a-single-USRP-2920-tansmit-Tx-and-receive-Rx-at-the....
Let me know if that helps, or if you have additional questions!
Sunayna R.
Applications Engineering
(3,284 Views)
Thank you so much.
(3,278 Views)
Hello, nauman_malik1112.
I am a college student studying USRP in Korea. I am also working on relaying data to destinations using a repeater like you, and I would like to refer to your Relay.vi file, but it is impossible.
Can you tell me what version of LabVIEW you used and tell me where you got the Relay.vi file?
(2,462 Views)
