USRP Software Radio
usrp 2922
hello,
i am using usrp 2922 with matlab R2017a, but i have a problem with the firmware version, matlab shows this message : usrp radio at '192.168.10.2' is not compatible with the host code build, update the usrp radio framware to version '003.009.004-vendor'. but i can't find this version. so i need your help.
thanks
best regard
(3,157 Views)
The firmware should be specific to work with Matlab software, you can probably find more information here
https://www.mathworks.com/help/supportpkg/usrpradio/ug/update-usrp-radio-firmware.html
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(3,121 Views)
Thanks Paolo_P,
I found the sollution by using the last version of NI-USRP Configuration Utility.
(3,115 Views)
