USRP Software Radio
usrp integration with OFDM tx and rx
Hi everyone,
I am trying to integrate an OFDM Tx and Rx with NI USRP but I am having a problem to deal with the usrp blocks tx and rx and I am having a problem in setting the parameters. So if anyone can help me I would be really grateful
(6,096 Views)
Hello Abusala7,
I opened the OFDMTX and OFDMRX VIs in the zip folders you posted. I'm guessing those are the ones you're having trouble with.
I'm not sure where you got this code from, but it's fairly well documented. What I suggest is that you open the block diagram and hit Ctrl+H to open the context help. You can then hover over each block and understand what it does, and thus understand what its parameters are.
Hope this helps. If you have specific questions, let me know.
Tarek B
(6,071 Views)
