USRP Software Radio
usrp transmitter
I am working with the following vi. How should I check if it is transmitting to the usrp. I am trying with fm radio  in my phone but with that I am not detecting anything. Please help.
(3,119 Views)
You should post to the usrp board: http://forums.ni.com/t5/USRP-Software-Radio/bd-p/500
You can click on the 'Options' link and request that the moderator move your post.
(3,110 Views)
What carrier frequency is being used in the application?
The default value in the VI is 100 KHz which is outside of configurable range and outside of the FM band if that's what you are trying to use on your phone. Also what is the IQ rate being used?
Also I think you should use the complex double (CDB) version of niUSRP Write Tx Data vi.
(2,773 Views)
