USRP Software Radio
why the receive signal throught the bandpass filter don't stable?
When I design the Receiver Module which is based on the amplitude demodulation and the USRP module,I found the receive signal throught the bandpass filter don't stable.I didn't how to modify it,please tell me where is wrong and how to modify.
(4,896 Views)
Am must be acquired off the LO frequency due to a DC offset filter that distorts AM when it is acquired at DC. I recommend using the LO property node to set the LO to a nearby frequency and the center frequency parameter to your center Frequency. With that combination the DC offset filter should be avoided.
(4,890 Views)
You means to replace the "Carrier Frequency" use the  "LO property node " or add the "LO property node "  in the front of  the "Carrier Frequency" or what else? I don't konw how to do it ,please  guide me modify it,think you!
(4,875 Views)
