UVLabVIEW
Unable To Talk to Power Meter Via GPIB
Hello all.
I have Labview 2016 installed. NI Max installed. I am using a Agilent 82357B USB to GPIB converter. I have only 1 device on the GPIB interface. It is an Agilent E4418 power meter.
When I installed the Agilent/Keysight IO library, I specifically set it to be the Secondary option on the bus.
NI Max sees:
ASRL1::INSTR "COM1"
ASRL3::INSTR "COM3"
and the GPIB interface and power meter (GPIB address 13) as GPIB0::13:INSTR "Power Meter."
If I open the VISA Test Panel, and select IO Control, I can send a "*IDN?" query and get the appropriate response.
HOWEVER, if I drag GPIB0::13:INSTR in to a VI, and select 'Refresh', I no longer see the interface.
Anybody know why I cannot see the interface in Labview?
-Shawn
(8,101 Views)
Hi Shawn,
Where do you work in SLC?  I can come by for an hour or so and see if I can help you get up and running.  My email is bryan@endigit.com.  Can you send me your contact info and we can set up a time for me to come help?
Bryan Heslop
Endigit
(8,068 Views)
All,
Bryan was able to help me out. The "problem" (as I understand it) was that in LabView the Agilent GPIB interface was actually being used and addressed as a VISA interface.
Once we used the Instrument IO | VISA writes and reads (instead of the GPIB commands) I was able to communicate with the instrument.
Until yesterday...
I am doing the self instruction lessons that NI offers. I'm in Lesson 8 now. In this lesson, you open NI Max and install the DAQMx suite. Then you select the NI PCI-6225 as an instrument.
I completed that lesson and tried to talk to my power meter at GPIB address 13.
I am unable to communicate via GPIB.
I think the reason is NI Max has now moved my GPIB0::INTFC to "? Miscellaneous VISA Resource"
As a result, in a VI, the GPIB port is no longer seen as an interface.
Does anybody have any idea how to get my GPIB interface back in to a VI?
Screenshots are attached.
-Shawn
(7,934 Views)
Disregard.
I figured it out. The problem was I powered down the power meter, then rebooted the PC.
Once the PC came up, I ran NI Max with the power meter still turned off.
Later, I turned on the power meter, refreshed several times and never saw the power meter.
I took a break from it and left the power meter on. I woke up the PC, restarted NI Max, and my power meter appeared in Devices and Interfaces as it did before.
Tip: Make sure your instruments are powered on before running NI Max.
I hope it helps someone else,
-Shawn
(7,930 Views)
