Unit Testing Group
New Add-on for JKI VI Tester enables Jenkins Integration
JKI has just released an add-on for VI Tester called JUnit XML Test Results that that facilitates integration with the Jenkins continuous integration software (e.g. if you want to automatically run all your unit tests every time you push code to your source code control system).
Read all about it here: http://blog.jki.net/new-add-on-for-vi-tester-enables-jenkins-integration
(4,190 Views)
Yes! This makes me very happy and leaves me with no excuse to not get CI setup!
I will try and push something using this and my CLI library once I have it done which should make it super easy to get this working with Jenkins
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(4,150 Views)
