Unit Testing Group
UTF for RT user-defined tests crashes. What are my options.
I'm just giving my brief story version. Apparently UTF works because this forum is here 🙂 I need a sanity check.
LabVIEW 2015 crashes when I execute a User-Defined unit test. Sometimes it crashes when I simply open the UTF configuration dialog, depending on the VIs tested.
I moved one of my .lvlibs to a new .lvproj so there is a minimum of VIs and files involved. Test execution did not crash, but the user-defined output cluster says Pass and the UTF report dialog says Fail.
These are RT VIs, the project contains some old code, some classes. I inherited most of it. Runs good. Should I tell the customer to use VI Tester? Upgrade to LabVIEW 2017 (not likely we're under severe IT)? Rebuild my project, .lvlibs, .lvclasses from scratch until I find the root cause? Ask the AEs to fix it?
cc
Message 1 of 1
(3,107 Views)
