User Group Resource Center
Introduction To The TDMS File Format
Collecting measurement data, saving it for reuse, and sharing it with others can be challenging. Explore the benefits of Technical Data Management Streaming (TDMS) as a file standard versus other storage techniques, and learn data-saving best practices to get the most out of your test data.
(9,897 Views)
To all presenters:
Simple instructions for the "Getting Started with TDMS" demo:
  1. Place down a DAQ Assistant Express VI and configure a Voltage task.
  2. Select the "Logging" tab.
  3. Enable TDMS Logging and [optionally] customize a TDMS Group Name.
  4. Select OK.
  5. To [optionally] customize properties of the TDMS file:
    1. Remove the Diagram Disable Structure from the diagram.
    2. Wire the TDMS Task Out from the DAQ Assistant
    3. Enter property Label / Value information.
  6. Run the VI.
  7. Open the TDMS file and browse the data and optional properties.  DIAdem is an optimal choice, but Excel works, as well.
Derrick S.
Product Manager
NI DIAdem
(5,654 Views)
