VI Analyzer Enthusiasts Discussions
Guidance on testing .ctl files of a class for default icon
Hello, I have succesfully tested all the VIs in a large project to determine which ones still have the default icon, but would also like to check if the .ctl files in a class have their default icon as well. As far as I can tell the built in VI analyzer test only checks .vi files. Will I need to write a custom test to do this?
Thank you!
(3,048 Views)
There is no way for the VI Analyzer to check the private data control of a class, because as you mentioned, the private data control is not actually a VI file on disk. You would need a separate utility (or a hacky VI Analyzer test) to check it.
(3,046 Views)
Ok, thank you for the help!
(3,024 Views)
