VI Analyzer Enthusiasts Discussions
How to leverage code of existing tests?
There is a wealth of useful code in the existing tests, and creating a new test can often be simplified dramatically if we could start out with existing code, modify parts to suit our changed requirements, then save it under a new name in the custom tests.
The stock analyzers are at the following path:
C:\Program Files (x86)\National Instruments\LabVIEW 2014\project\_VI Analyzer\_tests
But is is impossible to copy an existing test, place it in "LabVIEW data" and start modifying and renaming, because of lvlib memberships, etc.
I guess easiest would be to create a new custom test and then copy/paste the code of an existing VI into it. Is this the recommended way? Is there a better way to do this? Anything to watch out for?
(4,299 Views)
The approach I always take is to use Tools > VI Analyzer > Create New Test, then copy/paste code from existing tests into the VIs that are in the new test LLB.
If you already have a (non-licensed) test that you want to copy, you can make a file copy, then use the Test Rename utility here: https://decibel.ni.com/content/docs/DOC-31629
(3,246 Views)
