VI Analyzer Enthusiasts Documents
List of Community VI Analyzer Tests
The following is a list of community-contributed VI Analyzer Tests:
Anti-Aliased Plots
Auto Error Handling Detect or Correct
Block Diagram Background Color
Broken VI Extended (exclude FPGA VIs)
Case Sensitive String case structures
Check Captions and Labels Match
Check for Whitespace in FP names
Check VISA read/write Synchronous mode
Check whether Tunnels use default values if unwired
Checks whether references are closed
Comparing Variants
Constant Documentation
Copyright
Custom Control / TypeDef Style
Deprecated Functionality
Detect Mechanical Action
Detect Pre-Allocated Clones
Diagram Size and Position
Enum Constant Value Changes
Events that Lock Panel
Execution System Setting
Find Constant By Class Name
Find Control
Find Disable Structures
Find Dynamic SubVI Calls
Find Event Structure Frames
Find Function
Find Numeric Constant Value
Find Property or Method
Find Text
Find Typedef Instances
Find Unbundle By Name
Find VI Calls
Find XNode
Fix Gray Classes
Forked Event Reg Refnum Wire
Front panel control naming convention
Front panel controls are typedefs
Front Panel Size
Inline VI Marking
In Range Exclusion
In Range and Coerce comparison mode
Key Navigation
Launch Actor Called in Pre Launch Init
Limit to single line
LVLib Usage
Merge Errors Style
Minimum Window Width
MScript Nodes
Naming Convention
Open Actor Core Front Panel Set to True
Panel Color
Poly Instance Inventory
Priority Setting
Property Node Name Format
Reentrancy
Search and Replace
Separate Compiled
Shift Register Initialization
Skip Subroutine Call If Busy
Subdiagram Labels
Subroutine and Not Reentrant
SubVI Owning Location
SubVIs Need Relinking
Swapped Range Inputs
Unnecessary Class Casting
Unwired Event Nodes
Unwired Event Timeout
Useless Close Reference
VI / FP execution state flags
View Cluster Constant as Icon
Feel free to add your own tests to this list as you post them to the LabVIEW community.
Comments
ghighuphu
Active Participant
Active Participant
on
Follow the instructions at How to Install and Use a Custom VI Analyzer Test to install and use these tests.
SnelleJelle
Member
Member
on
Isn't there a way to download them all at once?
Rather than going through every link and download it separately
Darren
Proven Zealot
Proven Zealot
on
Most of these tests are for specialized use cases, so they are typically downloaded one at a time as those use cases come up.
francois-normandin
Member Member
Member
on
Is there a test to check for RT compatibility?
For example, a VI that has a menu palette item should wrap it in a conditional disable structure to allow deployment on an RT target... that sort of things.
GCentral ChampionCLA
Darren
Proven Zealot
Proven Zealot
on
There's not a single "RT Compatibility" test that I know of. However, when you install the RT module, you do get some RT-specific tests in the list:
https://zone.ni.com/reference/en-XX/help/371361R-01/lvvianalyzerhelp/rt_tests/
