VI Analyzer Enthusiasts Discussions
Missing error codes in VI Analyzer help file
2 error codes are missing from the VI Analyzer Help File : https://zone.ni.com/reference/en-XX/help/370928G-01/lvvianalyzer/vi_analyzer_error_codes/
The 14216 and 14217 errors are not listed here.
Do you think that could be added ? As a TSE I had a customer that was facing the 14217 while using the VI Analyzer through CLI (he was trying to perform a project-based analysis)
He looked for the error, but couldn't find anything.
To find the error description, I had to go through the "Help>>Explain Error"
That's not critical at all, but that would be great for customers who don't know that LV menu !
Salah
(2,621 Views)
I have reported this issue to R&D as Bug 1156417. For now, you can see a list of all VI Analyzer Toolkit error codes in the following file:
[LabVIEW 20xx]\project\errors\VI-Analyzer-errors.txt
For convenience, here are the error descriptions for 14216 and 14217:
<nierror code="14216">
VI Analyzer: This VI could not be analyzed because another VI of the same name, but a different path, is already in memory.
</nierror>
<nierror code="14217">
VI Analyzer: The specified CFG file contains project-based analysis information. The VI Analyzer VIs only support loading CFG files containing file-based analysis information. In order to use a CFG file with project-based analysis information, you must load it in the VI Analyzer dialog box.
</nierror>
(2,597 Views)
