VI Analyzer Enthusiasts Discussions
Opening an rsl file in the result window by program
Hello everybody,
I've written a small program that allows a user to select a project and a "recipe" file (.cfg). It then launches the tests selected in the recipe on the selected project items.
When tests are finished, I automatically create an html and rsl file.
I want to automatically open the result window at the end of the tests. Is there a way to do it?
I've looked in analyzerresults.llb and analyzerui.llb but the only think I found was that the wizard communicates using FGVs. And when I manually write values into these FGVs, the result window make an init at launch and overwrite my values.
Thanks, Amaury.
(4,787 Views)
Are you using the VI Analyzer VIs? If so, there is an input to VIAn Run.vi called "Show Results Window?" that will automatically pop up the results window when the analysis is complete:
(3,950 Views)
Hi Darren,
thank you for your quick answer. I'm using ViAnalyzer API to perform tests so I can use the Show Result Window to automatically pop the window. I probably miss this input on the Run VI...
By the way, is there a solution to reopen a result file by program? I'm still curious...
Thanks a lot,
Amaury.
(3,950 Views)
There is currently no way to programmatically launch the Results Window with a pre-existing RSL file loaded...you have to manually launch it via Tools > VI Analyzer > Show Results Window, then pick the RSL file in the resulting file dialog.
(3,950 Views)
