This test returns a failure for any subVI call that is set to 'Skip Subroutine Call If Busy'.
The test also includes an option to modify subVI calls to turn off this setting. Note: When using this option to programmatically modify your code, make sure you have a backup of your codebase.
This test is saved in LabVIEW 2018. Follow the instructions here to install and use this test.
