VI Analyzer Enthusiasts Discussions
VIA Test - custom location
Hi All,
Is there possibility to create VI in new location, such as ..\Documents\LabVIEW Data\VI Analyzer Tests\<New Folder>  or completely new location
When I choose create new test under tools>>VI Analyzer, I was not able to modify default path.
Hemalalitha
(5,197 Views)
Accepted by topic author hemalalitha
The VI Analyzer Test Creator will always create the new test LLB in the [LabVIEW Data]\VI Analyzer Tests folder. You are free to create subfolders within there and move your test LLBs into the subfolders...the folder hierarchy under {LabVIEW Data]\VI Analyzer Tests will be correctly represented in the VI Analyzer UI.
(4,379 Views)
Thanks, Darren
(4,379 Views)
