VI Analyzer Enthusiasts Discussions
What kinds of things can be broken on a diagram?
I'm writing a VI Analyzer test that involves detecting items within a subdiagram (like a case of a case structure) that might be broken. So just checking if the VI is broken isn't granular enough, I want to know the broken things on a certain subdiagram. Here are the things I can think of that I could detect through scripting that would tell me a subdiagram is broken:
1. Broken wire
2. Broken subVI (including a bad subVI linkage)
3. Unwired required parameter on a function/subVI
Can y'all think of anything else?
(3,649 Views)
Array constant undefined type
(3,599 Views)
and a few more:
missing SubVI (probably falls into broken SubVI)
format string problems with "Format into String" node
missing type definitions / other type definition problems for constants.
Scratching my head a bit around bundle/unbundle.  I think most of these errors would be found through broken wire checks.
(3,598 Views)
Thanks, Warren. I've added your suggestions to my test. Let me know if you (or anybody else reading this) can think of other broken items I can check for.
(3,588 Views)
