VI Analyzer Enthusiasts Documents
Words to Add to Spell Check Dictionaries
The following lists contain suggestions for words to add to the standard and technical dictionaries of the VI Analyzer Spell Check test in a future release of the toolkit. This list can be edited by any member of the VI Analyzer Enthusiasts group. Please see the Dictionary Details document for additional background information on the different dictionaries used by the VI Analyzer Spell Check test.
Proposed New Words
Standard - (add new proposed words here)
Technical - (add new proposed words here)
dbfs, fifos, flexrio, lvlibp, mux, rfmx
Words Added in VI Analyzer 2014
Standard - amped, attenuator (attenuators, attenuating), barcode (barcodes), bitwise, checksum, convolve (convolved, convolves), crosstalk, decrypt, digitizer (digitized, digitizing, digitization, digitizers), doubler (doublers), intermodulation, metastable, metrology (metrological, metrologically, metrologist, metrologists, metrologies), microcontroller(s), nonlinearity (nonlinearities), nulls, pong, preamp (preamps), probabilistic (probabilistically, probabilism), reflectivity, repeatability, roundoff, screenshot, subassembly (subassemblies), subtype, swizzle, symbology (symbologies), taskbar, unhandled
Technical - acq, acqs, acvolts, agilent, amp, ampl, anritsu, applicationmgr, applicationmanager, areaheight, areawidth, arg, aspropertyobject, atten, attn, autotune, autotuning, aux, avg, avgs, bitrate, bumpless, cal, casesensitive, caseinsensitive, chan, channelindex, channelname, channelnumber, chien, classdriver, classname, clientsequence, clk, closehandle, closetransaction, cmd, cohen, columnheader, (columnheaders), comparemethod, comparemode, comparisonmethod, comparisonmode, computername, cp, cpk, currentlimit, custombytecount, customtimeout, dac (dacs), dataset (datasets), datetime, db, dbc, dcvolts, deadtime, deallocation, debounce (debounced), debugger, decoupler, deltatime, deskew, div, divs, downconverter, dmm, dut, dutycycle, edgetime, endtime, equalto, errorlog, errormessage, errorquery, eyecrossing, fallingedge, falltime, feedforward, fileglobal (fileglobals), filepath, fract, frontpanel, fuzzify, fuzzification, getnumelements, getpropertyobject, getvalboolean, getvalnumber, getvalstring, ghz, globals, goto, greaterthan, highlevel, holdoff, hrones, idn, idquery, ignoreall, ignorecase, iinstrsession, iinstrsessionmgr, immediates, inputimpedance, inst, instrsession, instrumenthandle, intel, iviXXXXX (where XXXX is each IVI class, such as IviSwtch, IviRFSigGen, IviFGen, etc -- also including the ni versions like niSwitch), XXXXX (where XXXX is each IVI class, such as Swtch, RFSigGen, FGen, etc. also including ni version like niSwitch), keithley, keyfocus, khz, lessthan, linefeed(s), locals, logfile, logicalname, loginname, lookupstring, lowlevel, lowerlimit, lowlevel, lowlimit, maxvalue, measuredvalue, mfg, mhz, minvalue, mustexist, mutex, newsubproperty, nichols, nisessionmanager, nisessionmgr, nogo, nominalvalue, numavg, numavgs, numaverage, numaverages, objectname, opamp, outputon, outputoff, outputenable, outputenabled, outputoff, outputon, outputstate, pll, percentcomplete, percenterror, popup(s), prescale (prescales, prescaler), processmodel, processtype, propertyobject, quartile, readkey, recompiles, recordlength, reinitialization, repeatability, reporttext, rescan, reswick, reversesort, risetime, risingedge, runstate, runstop, rohde, samplerate, sampleswitch, schwarz, setpoints, seq, sequencecall, sequencecontext, sequenceeditor, sequencefile, sequencefilename, sequencefilepath, sequencelist, sequencename, serialnumber, sessionmanager, sessionmgr, sessionname, setnumelements, setvalstringbyoffset, setvalue, sg, siggen, sinusoid, squarewave, src, startup, stationglobal (stationglobals), stddev, stepname, stepresults, steptype, struct, stylesheet, subproperty, subproperties, subrate, svn, switchconfiguration, switchdevicename, switchexec, switchexecsession, switchexecvirtualdevice, swtch, tableheader (tableheaders), testcase, testdata, testequipment, testexecutive, testheader, testmode, testmodule, testname, testprocedure, teststation, testsystem, timebase, timeperdiv, timeperrec, timeperrecord, timestamp, timezone(s), triggerable, triggerholdoff, triggerlevel, triggerposition, triggerslope, triggersource, uncert, uniqueid, unversioned, upconverter, upperlimit, useddefault, userentry, userid, useroptions, uut, (uuts), validatenewelementname, validator, visainstr, voltsperdiv, vout, vpeak, vpp, wavetek, webservice, windowing, workingcopy, writebuffer, writefile, writekey, ziegler, zoomfactor
Comments
adambro
on
It would be useful if some of the words in the technical dictionary were case sensitive. I'm thinking about units really. Frequency for example has symbol Hz so therefore MHz or mHz should be permitted but mhz should not.
warren_scott
Active Participant
Active Participant
on
It would also be nice if there were a way to have an entry in the user dictionary that specified that items were case insensitive.  At this point for an item of "lowlevel", I need to enter
lowlevel
Lowlevel
LowLevel
lowLevel
LOWlevel
LOWLevel
lowLEVEL
LowLEVEL
which gets really annoying and long when you do that for all of those two word combinations that are commonly used by us engineers, especially if I want to allow any of the upper-lowercase permutations.
warren_scott
Active Participant
Active Participant
on
More stuff I have found that I wish was available/fixed for spelling checks in VI Analyzer:
(as of 2012) it is flagged as debug enabled.  Most VI analyzer stuff is flagged as debug disabled.
I wish I could have a user dictionary (that had ability to have case sensitive and case insensitve stuff), and a project dictionary -- meaning a specific dictionary just for this VI analyzer configuration/project.
I wish I could specifically ignore the file name spelling checks while still checking VI description.
It would be great to check a box in the configuration and automatically split CamelCase words into separate parts and check the individual Camel Case words.  That way I won't need to keep adding all the standardized CamelCase usages we have to my user dictionary.
I've run into a few issues with really long strings (either when long string constants somewhere, or more often when I end up analyzing all the values in a multicolumn listbox with values still in place after an execution due to whatever bad coding practice in place that leaves MCLB values in place after execution completes and gets saved with VI).  It would be nice to have a "Ignore strings longer than NNNNNN" in spell check options.
Darren
Proven Zealot
Proven Zealot
on
Thanks for the feedback, Warren. I have filed myself CAR 562373 to try to get some of these improvements implemented in a future VI Analyzer Toolkit release.
warren_scott
Active Participant
Active Participant
on
I just ran through a refresh of our internal custom user vi analyzer spell check dictionary (which is case insensitive) against the shipping LV2017 dictionaries.
Below is what we are using in our custom user dictionary that makes sense to add to the community-at-large or maybe even LV 201(n+1).  No real preference as to standard dictionary vs technical.  Sorry about the formatting -- I'm not a forums wizard.
acc
accurrent
acos
acpower
acpowersupply
acqmode
acqtype
adc
addr
adj
admin
advantest
afg
andon
antistatic
apis
apps
arb
archivable
arduino
areoflex
arrayname
asin
assetnumber
assoc
asymptotic
atan
atm
atml
att
attr
attrib
auth
autodetect
autogenerated
autolevel
autoleveling
autoranging
autosave
autoselect
autoset
autosetup
auxout
ave
avtech
backdoor
backlight
backlit
balun
bandwidthlimit
bert
bertester
bertesters
bertscope
bertscopes
bilevel
binarysearch
bitness
blowby
bnc
bncs
bootloader
bootup
bottomline
bowtie
bugfix
bw
bwl
cableclone
calconstant
calconstants
camelcase
carnegie
cert
certs
cfreq
cfrequency
cha
channellist
channelstring
chb
chinese
chk
chroma
chx
chy
clockfrequency
clockin
clockinput
clockout
clockoutput
clocksource
cls
clust
cmds
codeload
codeupdate
coef
coeff
coeffs
coercions
coldboot
coldboots
combobox
conf
configs
consts
contactcheck
corr
coupler
couplers
cpkhigh
cpklow
cpp
cru
csa
cstring
ctr
curr
cust
cytek
dacget
dacread
dacset
dacwrite
datafile
datafiles
datain
datalink
dataout
datapoints
datasheet
datasource
datasources
datecompare
datestring
datetimestring
dbase
dbdown
dccurrent
dcoffset
dcpowersupply
debouncing
debundle
debundles
decodekey
decrypts
defaultsetup
defaulttext
defaultvalue
degauss
dejitter
dejittered
delaytime
deletable
deltat
descriptors
dese
deserialize
deskewing
deskews
dest
detents
devl
differentiator
digipot
digipots
directivity
dirs
disconnectall
displayable
displaystate
displaytype
dist
dl
dlg
downlink
downsample
downsampled
dpo
dropoff
durations
dvds
dx
dy
ebits
edgetimes
eeprom
eeproms
eg
elapsedtime
enc
eng
enob
env
eq
errmsg
errormsg
ese
esr
eventcode
eventlog
eventmessage
eventtype
exceptioned
expr
extref
fastacq
feedthrough
fieldname
fieldnames
fieldtype
fieldvalue
filehandle
filehandles
fiso
fmax
fmin
foo
foreach
freqs
fullscreen
gbaud
ge
genlock
getdata
gethandle
gps
graticule
graticules
gsa
guardband
guardbanded
guardbanding
guardbands
hardcode
hardcoded
hardcopy
heterodyne
hexstring
hf
hg
highband
highlimit
highres
hipot
holdtime
hor
horiz
horizdelay
horiziontalposition
horizontalpos
horizontalref
horizontalreference
horizontalsettings
horizontalsetup
horizpos
horizposition
horizref
horizreference
horizscale
horpos
horposition
horscale
hpos
hposition
hscale
hscroll
huber
hw
hyperterminal
idstring
infiniband
initailization
initializations
inputlevel
intermod
internals
interp
interpolator
intranet
invalidateattributes
ipaddress
isdn
itar
iviclass
jit
jitt
jittered
jittertype
kaizen
ke
kei
keycode
keydown
keyname
keynames
keypress
keysight
keystring
keyup
ki
kss
labelprint
lan
lastresult
lecroy
len
lic
lifecycle
linenumber
linscale
logout
logscale
lowband
lowres
lowside
ls
lt
luminance
macaddr
macaddress
mainboard
mathcad
matricies
maximumvalue
maxsize
maxval
mbaud
mdo
measu
megohm
metadata
mgr
mib
midband
midlevel
millivolt
millivolts
mimo
minimumvalue
minindex
minorversion
minsize
minval
misc
mixedmode
mixmode
ml
modbit
modulename
moduletype
mousedown
mouseup
mscript
mscripts
mso
multipoint
mux
nameof
nano
nanovoltmeter
ne
newlines
nidcpwr
nireport
nise
nivisa
noiserej
noisereject
nolock
nplc
nsigma
nslookup
nulling
numacq
numacqs
numelements
oid
oidname
oidnumber
oids
onboard
ontime
openclose
orig
osc
overrange
oversample
oversamples
pairings
param
parentitem
passfail
passthrough
paycode
pcnt
pcs
peakdetect
peltier
phaselock
phaselocked
photodetector
photodiode
pico
picosecond
picoseconds
pk
pkdet
pkdetect
pkpk
pktopk
plls
polymorphics
postexpression
postuut
potentiometer
potentiometers
pow
powercycle
powercycled
powerlevel
powerline
powermeter
poweroff
poweron
powershell
powersupply
powerup
pp
preamplifier
precal
precalibration
precheck
precond
preexpression
preload
preloads
preshoot
preuut
proc
programatic
propertydescriptor
propertyexists
propget
propobj
propset
proxycaller
psexec
pulsetrigger
pulsewidth
pwr
pxi
pxie
qty
qual
rasterizer
readback
readbuffer
readdac
readdata
readfile
readlist
readonly
readvalue
readwfm
recalibrate
recalibrated
recognizer
recordlengths
recursing
refch
refchan
referencein
referenceout
refin
reflevel
reflock
reformats
refout
refwfm
regex
regularexpression
reinstall
relaystate
releaselock
releaselocks
repo
responsivity
resultcount
resultlist
resultprocessor
resync
retransmission
retransmissions
retrigger
returncode
returnloss
returnmsg
rf
rgbout
rgboutput
rgboutputs
rgbs
rolloff
rolloffs
rom
rst
runmode
rx
samplemode
samplingmode
scaledresult
scc
searchstring
sectionheader
sectionname
sectionnames
selftest
sens
sensorid
sequenceanalyzer
sequencefailed
sequencefileload
sequencefileunload
sequencepassed
sequencestart
sequenceview
ser
serializable
serialtrigger
shortname
sideband
sidebands
sigloss
signalloss
signalout
signalsource
signaltype
sitename
skewvalue
slewrate
sma
smu
smus
sn
sngl
snubber
sourcefreq
sourcefrequency
sourcelevel
sourcemeter
sourcepath
spanish
sre
sru
stairstep
startfrequency
startindex
startstop
starttest
starttime
stb
stdev
stim
stopafter
stopfrequency
stopindex
stopstart
stringin
stringout
subdir
subdirs
subinventory
submodule
submodules
subprop
subprops
subsequence
subsequences
substep
suhner
svc
sw
sweeppoint
sweeppoints
sweeptime
syst
tasklist
tdr
tds
tekconnect
teklink
tekvisa
terminators
testexec
testmethod
testpoint
testpoints
testsignal
testsocket
testsockets
testtime
tk
toplevel
topline
torr
tostring
tri
trianglewave
triax
triggeredge
triggeredgesource
triggermode
triggerpos
triggerpulse
triggersetup
triggerwidth
trigholdoff
triglevel
trigpos
trigposition
trigsense
trigslope
trigsource
trigwidth
trilevel
trimwhitespace
tsa
tsengine
tsvariablename
tx
tyco
typ
typea
typeb
un
unbiasing
underdrive
underrange
unencrypted
ungroup
ungroups
unitless
unitvalue
unk
unlogged
unmanaged
unpublish
unscaled
unsetbusy
upsample
upsampled
uptime
userdialog
userevent
usergroup
userinfo
utils
vals
variablename
varicap
vars
vbars
vbias
vbs
vco
vert
verticalpos
verticalposition
verticalref
verticalreference
verticalsettings
verticalsetup
vertpos
vertposition
vertref
vertreference
vertscale
vianalyzer
videoin
videoout
vin
viname
viodia
virefnum
visacache
visaconf
visaio
visaquery
visareset
visaresource
visaresourcename
visawrite
vmeas
vmeasure
vneg
voltagelevel
voltagelimit
vpos
vposition
vref
vscale
vscroll
vsource
vterm
vu
vw
warmboot
warmboots
wfms
whiteflag
whitelist
whois
wiki
windowtitle
writedac
writedata
writelogfile
writevalue
ws
wsdl
xbar
xilinx
xing
xl
xmcd
xtal
xval
xvalue
xx
xxx
ybar
ycbcr
ypbpr
ypbprout
ypbproutput
ypbproutputs
yval
yvalue
yy
zz
Frozen
Active Participant
Active Participant
on
Using LV 2020 SP1 I had to add the following:
dB
dBm
dBmV
hardcode
hardcoded
hardcoding
interruptible
JIRA
multiplier
rnd
RX
SPAM
TX
uncorrectable
uninterruptible
Former Certified LabVIEW Developer (CLD)
Contributors
