VXI and VME
1394 Slot 0 viMoveOut16 error
I just updated NI-VISA from 2.5.2 to 3.2. When I now run my application I get a bus error during a viMoveOut16 function call. Using VIC I was able to determine that viMoveOut16 will return a bus error code when the transfer count is > 2000. Is there a setting to increase the transfer count?
(6,639 Views)
I would like to try to reproduce this issue on my end. Could you give me the steps that you took to see this error bus error? Also, when you say the transfer count > 2000 do you mean 2000 hex, binary, decimal . . . ?
Thanks!
Erick D.
NI Applications Engineer
(6,638 Views)
