VXI and VME
Addressing error
I'm building a system that has a VME chassis and a PC, communicating over a MXI-2 card.  I've built several of these systems before, they are all exact copies of each other.  (The address settings are the same, etc.)  On the most recent one, I started seeing this problem: when I run resman, I get an error: "device at logical address 101 did not respond to read protocols command (error 0xBFFF0038)".
If I change the address of the chassis to something other than 101-127, the error goes away.   The thing is, the address has to be set to 101 per customer specifications.
Since I have a few systems around, I tried switching out the MXI-2 card.  The problem was still there.  I tried using a different cable, same problem.  Different PC, same problem.  I tried a different chassis, same problem.  So it looks like suddenly I have a bunch of bad hardware, but I can't isolate the issue to any particular piece, its only when the pieces are put together that the error appears.  However, I do have an old, good chassis/card combo that I used to verify the PC and cable are working properly, so I'm pretty sure the problem is in the current chassis/card combo.
Any ideas about this would be appreciated!  Thanks!
(6,760 Views)
Hey Speakers,
I'm kinda curious that swapping out the parts with another identical system can't narrow down the cause of the problem. Instead of trying 1 new part in your problem chassis. Could you try 1 part from your problem chassis into a working system untill you can find the part that causes the working chassis to fail. I would say if none of the hardware seems to have the problem follow it, I would recommend to repair the NI-VXI driver, but it seems that since you tried a different PC, that shouldn't be the problem.
Let's say to make it simple, let's Say Chassis A is a good chassis, and Chassis B is the bad chassis. and you have:
A1 A2 A3 A4 A5 <-> B1 B2 B3 B4 B5
    (Fine)                           (Problem)
first switch should be
B1 A2 A3 A4 A5 <-> A1 B2 B3 B4 B5
   (Fine)                             (Problem)
Finally after a few switches,  I'l be really suprised if finally, you do not see the problem follow the hardware at:
B1 B2 B3 B4 A5 <-> A1 A2 A3 A4 B5
    (Fine)                            (Problem)
If above, the problem still stays in the same unit, switch the final unit (B5) and see if the problem follows that.
B1 B2 B3 B4 B5 <-> A1 A2 A3 A4 A5
    (Fine)                           (Problem)
If after you switch everything, and now all the B units work, and the A Units do not, there's got to be something else that has not been switched between the hardware.
********I'm not trying to make it too simple my explanation, this is for me the easiest way to explain it
****** I know you've tried swapping the parts, but even if it were software or hardware related, there's no reason the problem shouldn't follow 1 of the hardware parts.
Nick D.
(6,741 Views)
