VXI and VME
Bus error during viIn and viOut
I have an application that was working and is now reporting a bus error with both viIn and viOut functions to A32 memory. A16 memory works. What conditions would cause this error?
(6,850 Views)
I cannot think of any obvious reasons that this would happen offhand. The only thing I can think of is that you may be trying to read a bad offset. Other than that, we'll probably need some more information to help you out with this. Exactly what is the error you are seeing? Also, what has changed (either in software or hardware) between the time that it used to work and now?
john m
(6,845 Views)
