VXI and VME
Can I install Labview 8 w/out changing dll's or DAQMX
Can I custom install LabView 8.0 without changing DAQMX or the drivers.  It is in a test setup that the owner does not want to change.
Here is the system info:
National Instruments Technical Support Form (Version 3.1.1.3004)
Generated: Wednesday, May 10, 2006 11:26 AM Eastern Daylight Time
User Information:
Registered Owner: Raytheon
Registered Organization: Raytheon
Address:
City:
State:
Country:
Postal Code:
Phone:
Fax:
Email:
System Information:
Operating System(OS): Microsoft Windows XP
OS Version: 5.01.2600
OS Info: Service Pack 2
Processor:               Intel(R) Pentium(R) 4 CPU 3.00GHz / x86 Family 15 Model 4 Stepping 1 / GenuineIntel / 2992 MHz
Number of Processors: 1
Physical Memory: 515,520 KB RAM
Drive C:\ 10,415,228 of 20,482,840 KB free
Drive D:\ 53,801,164 of 57,665,284 KB free
NI Software Information:
CVI Run-Time 7.1.1.350
NI-DAQ 6.8.0f9
NI-488.2 Software 1.60
NI-IMAQ Software 2.21
IVI Engine 1.6
LabVIEW 6.0
LabVIEW Run-Time 6.0
Measurement & Automation Explorer 3.1.1.3003
Motion
     FlexMotion 5.0
     ValueMotion 5.0
Measurement Studio 6.0
     For Visual Basic
          ActiveX User Interface 6.0.3.594
          ActiveX 3D Graph 6.0.3.601
          ActiveX DataSocket 4.0.3.367
NI-PAL Software 1.8.2.0
NI Spy 2.1.0.12
NI-VISA 3.2
     visa32.dll 3.2.0.19
     NiVisaServer.exe 3.2.0.19
     NIvisaic.exe 3.2.0.19
NI-VXI 3.5.0
     nivvglk.sys 1.5.0.45
     nivxint.dll 3.5.0.35
     nivvglu.dll 1.5.0.45
     cfgeng32.dll 1.5.0.35
     cfwgmxi2.dll 1.5.0.35
     cfwg1394.dll 1.5.0.35
     wmxi2ext.dll 1.5.0.35
     niini32.dll 2.6.0.1
     niresmanengine.dll 5.0.1.37
     resmanguivvgl.dll 2.0.0.324
     resman.exe 4.0.0.246
     NIDeviceConfig.dll 2.0.3.32
LabVIEW Run-Time 7.0
(7,754 Views)
Robert,
At installation, you can choose not install the drivers.  This will leave any drivers that you already have installed on your pc.  If the LabVIEW 8 installation prompts you for driver cds, you can cancel the installation at that point.
L. Allen
(7,727 Views)
I am not interested in how to do it but if LabView 8 will work with these old drivers.
(7,724 Views)
The daq drivers sshould be the only tricky ones.  They will work, but you will have to re-install them using the procedure in the link below.
[link removed]
L. Allen
(7,717 Views)
