VXI and VME
Can VXI-MXI-2 daisy chain as output of 10MHz distributin amplifier
Can two VXI-MXI-2 be daisy chained as an output of a 10MHz distribution amplifier?
(6,273 Views)
I am not sure that I understand exactly what you mean by your question, but the VXI-MXI-2 is designed to be a VXI compliant extender class, register-based, slot 0 controller and bus extender for both the data lines and all trigger and interrupt lines. If that is withing the scope of what you are asking, great! Also, please refer to the following resources to learn about the capabilities of the VXI-MXI-2 board.
VXI-MXI-2 User Manual
Josh Hernstrom
(6,273 Views)
