VXI and VME
Does RESMAN have any command line parameters?
I've written a program that launches RESMAN on startup, but after RESMAN completes successfully, the RESMAN progress dialog doesn't dismiss itself, it waits until somebody hits the "close" button. I noticed that the T&M Explorer automatically dimisses the window when it's done, so I'm thinking there must be some command line parameters or switches that I can specify.
(7,556 Views)
ep138:
You can give RESMAN the parameter '-o' and it will run silently, and the user will not have to press the "close" button.
Trey Hamilton
http://www.ni.com/support
(7,556 Views)
